swap w/o car lift?
Re: swap w/o car lift? (Smokinsax)
Yup, I've seen it done. You need a team to do this, one at every corner of the engine and possibly one person under it for support. I gotta say you definitely need some man power here. Good luck
Good luck! Just borrow an engine hoist an you're good to go. No lift needed. This is the method i've used for years, well 4 or 5 anyway...
It can be done out the bottom i have done it and seen it done a few times....its not hard really just make sure you can "lift" the car car up high enough to get the motor out from under it. good luck
Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax »</TD></TR><TR><TD CLASS="quote">So, are you saying to use an engine hoist to lower the engine (from above) through the engine bay to the ground?</TD></TR></TABLE>
yes.
this is the most popular way., unless u have a wonderful amount of access to a nice lift and a pretty well stocked shop.(which most of us dont )
yes.
Re: (Smokinsax)
The photos arent the best, but these guys used a hoist to lift the car up........
http://www.h22hybrid.20m.com/photo.html
Personally i went traditional and used a hoist to drop the motor in from the top. But to each his/her own.
here ya go. i used the same rope to drop the engine down that i did to wrap aruond the frame to lift the car. it was simple this way. just watch out for the exhaust tip
Re: (corso28)
i have done it twice now each time with three people total. you jsck it up from the oil pan just out wood between engine and jack and the tie a rope or strap to the trans and just jacket it up and guide it in. then the other guy just bolts the motor mounts in very easy actually
The Boot
Re: (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">The photos arent the best, but these guys used a hoist to lift the car up........
Personally i went traditional and used a hoist to drop the motor in from the top. But to each his/her own. </TD></TR></TABLE>
thanks for the pics man...it really helped me to get a better idea on how some people went about it.
Re: (Smokinsax)
YOu guys are all doing it the hard way.
All you need are two floor jacks. Using hte jack point below the doors on each side of hte car you can raise the car enough to get hte motor in and out. If you need pics i am pretty sure we have some of our last swap. Did it high enough to push an h22 under it.
here is one pic.
http://www.imagestation.com/pi...c.jpg
here is one pic.
The Boot
Re: (HavokB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HavokB18 »</TD></TR><TR><TD CLASS="quote">YOu guys are all doing it the hard way.
here is one pic.
wow...that looks simple enough.
here is one pic.
Re: (Smokinsax)
iT IS AND it takes no muscle whatsoever. YOu can lower the entire chassis ALL they way to the ground with some stock honda jacks or a slim floor jack.
Re: (Smokinsax)
Dude someof you are living way to luxurious. I have done my last 4 swaps by MYSELF with the method mentioned above. I just slide the motor under the car which is supported by jackstands, take turns on lowering each side of the car/adjusting motor to line up to mounts, then do the rear mount first then both the side mounts. I do all this in my garage with 2 jacks, 2 stands, and 1 person.
Re: (b00sted EG)
Not a big deal at all.....I have done motors with and without lifts as well as with and without air tools......
Just get the car up high enough and it's a breeze!
Re: (onejdmchris)
we have done many swaps this way.its very eazy with 2 people and a floor jack and jackstands. We put in my K20a in my eg this way in an hour and a half.
i used rims under each rear wheel and used an engine hosit to pick the car the restof the way up ..I got some tall jackstands and had the car 3 feet offthe ground. used to engine houist to pick the motor in the car /
MayorMcCheese
12-23-2011 07:34 AM
