JDM B16 into EG question
My friend bought a JDM B16A2 complete swap. We are going to put it in. Since they are right hand drive what is the process? Will we have to lengthen the harness to get the ECU to the passenger side? Thanks for the help.
Re: (B16B)
You use your stock harness plus the plugs from your JDM harness to get it to work. Its pretty stragiht forward. If it is an Si or EX you can just use that harness and just lengthen a few wires. GL
Re: (lsvt3c)
Which model EG? Depending on which EG it is you may have a couple of wires to add or change. What you want to do is use the EG's engine harness on the JDM motor. The only sensor on my Civic VX harness I had to legthen was the O2. What I did was open up the harness and reroute the O2 wires a different path so I wouldnt have to add wire to them.
John
John
highroller54
02-13-2007 08:29 PM
street95civic
08-22-2005 08:23 AM
