What would make the SRS light come on?
My SRS light came was on today. I have a 99 civic with a 94 gsr engine. Would the ecu have any part in that? Or is it strictly with the steering colum and the airbags..?
EDIT* searched again and found the answer...
I turned my ignition on when I had my seats removed.
Modified by sivik2nr at 10:29 AM 7/27/2004
Re: What would make the SRS light come on? (sivik2nr)
hmmm....check all the yellow cables under you steering column and dash to make sure nothing came loose. this is the SRS system wiring.
Re: What would make the SRS light come on? (KTeller8)
mine came on a long time ago.... it tripped me out, and i never take my car to the dealer. soooo i just disconnected both my airbags. ..
---there is a sticky in the accord forum. on basics for accords or something.. one of the mods there did a how to on how to reset the srs light... he told me its similar on all models... i have yet to try it. but, everyone i've talked to said it has worked..
ok i will check that out
EDIT* THIS?
BY: Iam7head
Due to popular demands, here is the guideline.
*car- 2002 accord 4cylinder(should work for all honda)
*what you need to know- your accord gen/year location of the srs service connector(MES or something)
*tools- paperclip, flashlight
The MES connector is located in the backside of the hood release latch for 6th gen accord.
The SRS connector's evil twin brother. The real deal is the one I am pointing at, the one that harder to reach. They both have the similar color of wires coming out so don't be fooled.
Another view
[IMG]
http://www.imagestation.com/picture/...b.jpg[/IMG]
Insert paperclip
For the poor souls without helms.
Erasing the DTC memory/resetting SRS light
1) turn ignition switch off
2) connect the scs service connector to the MES connector. Do not use a jumper wire
3) turn igition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector within 4 seconds after the light comes on
5) The SRS indicator will come on again. Reconnect the SCS service conector(or in ghetto world of honda, paperclip) to the MES connector(read: the yellow connector, see picture) within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been errased/clear.
8) turn the ignition switch to off and wait for 10 seconds.
I think there's some similar article/post in the past, but none with pictures, see if this would help some of the visual learning generations of honda owners. make it sticky will ya?!
EDIT* THIS?
BY: Iam7head
Another view
[IMG]
Insert paperclip
1sikgti
01-17-2005 11:03 AM
