Problem with B18B swap in EG
Old Jul 23, 2004 | 09:42 AM
zaknafein's Avatar
Default Problem with B18B swap in EG
I swapped a B18B1 with a P75 ecu into my 92 civic lx
Everything is fine, the car can run, except that the motor runs extremely rich...
we found out that I have two map sensors... and the two connectors seems to be working......
could it be what makes the engine running rich ??? or could it be vacuums plugged at wrong locations ???
Old Jul 23, 2004 | 01:02 PM
zaknafein's Avatar
Default Re: Problem with B18B swap in EG (zaknafein)
no ideas ?
Old Jul 23, 2004 | 09:58 PM
saleensolution's Avatar
only one should be working and it should be the one on the throttle body because it has a specfic location that it gets its reading from. but i wouldnt think that it would make it run rich
Old Jul 25, 2004 | 07:01 PM
Jared's Avatar
Default Re: Problem with B18B swap in EG (saleensolution)
what engine harness did you use? is the vacuum line hooked up on the firewall map sensor? is your tps hooked up?
civicegb18
May 18, 2010 08:46 PM
mangabay
Jan 25, 2008 08:50 PM
Smallpox33
Aug 5, 2007 10:49 PM
spreng87
Sep 19, 2005 08:35 AM
zaknafein
Jul 27, 2004 01:17 PM
