Which radiator should I use for EG with B18C and A/C installed?
I have a 1993 DX Hatch with a B18C and A/C installed. Right now I'm using the stock DX radiator which seemed to be cooling ok, until you get into real hot desert heat and under load. The car starts to overheat with the A/C on and when its under a load like driving up a mountain.
Is there an effective direct replacement I could get? Any brands or part numbers you have would be great. Thanks for your help.
Re: Which radiator should I use for EG with B18C and A/C installed? (Hapa88)
im using an EG sir rad i got off ebay for like $50. has the larger spout that works perfect with the GSR rad upper hose.
cools like a champ. you might also look into getting a del sol dual core, or shell out some nice $$ for a koyoto or fluidyne for the GSR would be nice.
Re: Which radiator should I use for EG with B18C and A/C installed? (3 3 3)
Thanks for your input. Can you tell me how the EG SIR radiator different from the Del Sol Dual core?
http://www.1800radiators.com
get a 2-row 95 DOHC VTEC Del Sol Radiator. $75-$100 forgot....but my buddy has a 570whp daily driven gsr turbo hatch and it is humid as hell here in GA and has no cooling issues.
I LUV MY EJ1
08-01-2007 07:19 PM
explosive
11-01-2003 07:58 PM
bobbysteelz
07-29-2003 07:17 PM
