H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE?
HEY GUYS, QUICK QUESTION, I HAVE AN H22 TURBO IN A 4DR '93 CIVIC WITH AN H23 TRANS, AND CAME ACROSS A STOCK H22 LSD, JUST THE DIFF. IF I OPEN MY BELL HOUSING AND PULL MY OUT MY NON LIMITED SLIP DIFFERENTIAL CARRIER AND FINAL DRIVE, AND PUT IN THE H22 LSD, WILL IT WORK? ONLY RESPOND IF YOU KNOW THIS IS POSSIBLE OR ISN'T, OR HAVE PERTANENT INFORMATION PROVING IT CAN OR CAN'T BE DONE. THANKS.
Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (h22turbocivic4dr)
I dont think it can be done cause the main shaftes are diffrent in the lsd tranny then the h22 and h23 tranny.
Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (DxTrix)
what if he happened to have a regular, run-in-the mill h22 tranny...would the LSD transplant work in that case?
Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (CD5 Sedan)
i don't know if stock lsd is interchangeable but i know for a fact that aftermarket lsd is. I have asked both Cusco and Quaife is their H22 LSD will fit in an F22 or H23 tranny as well and both said yes.
h22civ
06-15-2007 07:47 AM
h22turbocivic4dr
08-04-2004 01:06 PM
