ls swap in crx
ls swap in crx
i finish the swap.. but my pullys scraps against the driver side stabilizer bar.. what do i use? accord bars? thats the only thing i can think of.. that might work.
Re: ls swap in crx (int3gLS)
I've had a 96 B18B1 LS motor and YS1 GSR cable tranny in my 91 CRX DX for 3 years now and I used the HASport billet mounts when they first came out. I still have the stock LS 3 belt crank pulley and have no clearance issues whatsoever. Are you talking about the pulley hitting the radius rod that connects from the front cross member to the lower control arms? Maybe it's slightly bent or something along those lines. Do you have or can you take some pics of the problem area?
Re: ls swap in crx (VTECVillain)
yeah the radius arm.. my pullys are scrappin it.. and i knoe the 90-93 accord radiusarm are bented down.. when our crx arm are straight.... what did u use? ill try to get some pic soon thou..give me some info on it thou.. i need asap.
I never had to modify or change the radius arms or anything at all, it's all stock with full front cross member, radius arms, etc. I even have A/C using the HASport A/C bracket.
DB'd
06-10-2007 03:47 PM
92gsrhatch
01-18-2003 07:15 PM
