IAC / Swap problems
Old Jul 27, 2004 | 10:22 AM
0evilEMPIRE0's Avatar
Default IAC / Swap problems
tried to search for the answer, no luck! everyone try this one out!
setup:
99 dx hatch w/ b18c1 (wired with 99 Si hardness for plug and play!)
stock Si ecu and / or obd1 P72 w/ Hondata
this is my situation:
after a long delay for parts, i finally finished my motor build. install was no sweat. Using a 99Si hardness, everything was p&p but the IAT sensor. With the use of a stock Si ecu and everything ready for start-up (ie. fluids), i went for it! What did i get? NOTHING!! KOEO there was no fuel pump action but a funny noise from the Main Relay and IAC area. So thinking that it might be the Main Relay, i replaced it and tried it again. Same thing, nothing! This time I unhooked the IAC valve, because it was making funny noises, with the KOEO. After doing that, the fuel pumped kicked on and it primed the system! so this is the problem that I'm having, with the IAC valve plugged in and KOEO, i get nothing! With the IAC valve unplugged and KOEO, the fuel pump kicks on!
does anybody know why this is happening? or what to do to fix this?
p.s. -
i also had a spare IACV and tried that one too, same problem!!
same thing happens when i use the P72!
Also have tried 3 different main relays to see if thats the problem, no go!
Checked to see if there was a short/open on the blu/blk wire side of the IACV,
checked out ok!
anyone?
Modified by 0evilEMPIRE0 at 6:16 PM 7/28/2004
Old Jul 27, 2004 | 11:32 AM
Default Re: IAC / Swap problems (0evilEMPIRE0)
anyone?
Old Jul 28, 2004 | 02:18 PM
ttt
Old Jul 28, 2004 | 03:52 PM
someone? anyone?
Old Jul 28, 2004 | 05:48 PM
no one?
Old Jul 28, 2004 | 07:04 PM
Old Jul 29, 2004 | 06:28 AM
so im up the river with no paddle?? someone has the answer!
Old Jul 31, 2004 | 08:13 AM
anyone?
Old Jul 31, 2004 | 09:09 AM
ttt
Old Jul 31, 2004 | 10:00 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
PLEASE GIVE US A CALL AT THE SHOP IT IS DETAILED NOT ENOUGHT TIME TO TYPE ALL THIS INFO 909-373-RACE
Old Aug 2, 2004 | 06:32 AM
Default Re: IAC / Swap problems (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">PLEASE GIVE US A CALL AT THE SHOP IT IS DETAILED NOT ENOUGHT TIME TO TYPE ALL THIS INFO 909-373-RACE</TD></TR></TABLE>
thanks
found out the problem, the ground for the engine harness on the t-stat houseing wasn't doin its job, so i had to run a new ground. finaly got it started last night , runs strong like bull !!
thanks to everyone for taking time to help me out
Old Aug 3, 2004 | 09:41 AM
DYNO-PRO
right on
Saeo
Aug 17, 2010 09:07 AM
0evilEMPIRE0
Aug 3, 2004 05:12 AM
SpoonFedHatch
Nov 11, 2003 11:43 PM
Anthonyl469
Dec 19, 2002 09:26 AM
rwcdrums
Jun 19, 2002 06:15 PM
