B18B Swap (PLEASE HELP)
Old Aug 3, 2004 | 01:27 AM
ludicrous's Avatar
Default B18B Swap (PLEASE HELP)
Hey Ya'll...
(did a serach and couldn't find any info)
Once again, i need help from ya'll...
I got a hold of a 2000 B18b from a friend...and my sister 's car needs a better motor anyways (cause it's burning oil big time) i figured i'll just swap it...
This is my first automatic swap...
The car :93 civic DX Automatic,
The motor : 2000 integ Ls Automatic (complete swap)
My questions is what mounts do i used? Do I use the stock mounts that comes with the B18? or do I have to get some other ones off of another Auto swap? Because for some reason I had the driver's side and rear T mount all installed...but the tranny side didn't want to line up. It was off about 1/2 inch. Tranny side tilted forward. Also tried the D-series tranny mount and the T mount...didn't work. Another problem was that the Alt. pulley was really close to the frame (about 1mm).
I must got some wrong mounts or something...PLEASE HELP...
BIG Thanks in advance...
Old Aug 4, 2004 | 04:58 AM
civicjester's Avatar
Default Re: B18B Swap (ludicrous)
integra swap into any EG civic you use all of the civic mounts except the driver side mount (by the timing belt)
Old Aug 4, 2004 | 02:59 PM
icivicracer's Avatar
Default Re: B18B Swap (crxjester)
acura engine in your eg.. use all eg mounts.. but u have 2 use the integra rear mount.. the 1 under the intake.. the pully is close but it fits i have a aem underdrive pully on mine and its close.. 98 ls ..in 95 civic Jrsc..and the wiring harnes should plug right in
Josh Bosh
Honda Civic (2001 - 2005)
Jan 20, 2018 08:59 PM
ludicrous
Aug 3, 2004 07:50 PM
ProJectCvic
Mar 17, 2004 05:25 AM
intezn
Jul 21, 2003 04:01 PM
hollywoodciv
Apr 22, 2002 10:22 AM
