b18b1 into ek hx coupe..how hard is it??
possibly going to buy a 97 hx coupe tomorrow with intention to swap in an obd2 b18b1 to be turbo'd over the winter. ive gathered that i need the rear tranny and upper drivers side mount from a 99si. since this will be turbo, i want to get full urethane mounts when i do the swap, but i cant find a full kit for this swap(should i just buy them individually?). another question i have is that i will be converting to obd1 so i can use uberdata. i would just need the obd2-obd1 harness and an ob1 ecu right? once i get the correct mounts and ****, how much of a plug and play is this swap going to be? just tring to get some info on this swap before i buy the hx, because ls turbo is a definate and the car that it is going into is still not set in stone
Re: b18b1 into ek hx coupe..how hard is it?? (blackeg)
ES makes inserts, or Hasport mounts will work. Yup just need that harness. It is plug and play. It took me 5 hours for my first swap. have fun.
Re: b18b1 into ek hx coupe..how hard is it?? (lsvt3c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvt3c »</TD></TR><TR><TD CLASS="quote">ES makes inserts, or Hasport mounts will work. Yup just need that harness. It is plug and play. It took me 5 hours for my first swap. have fun.</TD></TR></TABLE>
very good to hear. me and some buddies will probably wind up doing the swap over the course of a weekend(hard to get free time).
anyone else have tips or anything on this ?
TRDSUPRAT88
16
06-16-2004 08:11 PM
