which ecu to run with h22 civic swap without having to repin harness
i have a 94 hatchback with a 2001 h22a4 in it, which ecu should i use with the motor i am probably going to go with hondata but which one should i use as the base computer
Re: which ecu to run with h22 civic swap without having to repin harness (Cyberdx16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 »</TD></TR><TR><TD CLASS="quote">i dont think hondata runs with the p13... correct me if im wrong?</TD></TR></TABLE>
You would be correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 »</TD></TR><TR><TD CLASS="quote">i dont think hondata runs with the p13... correct me if im wrong?</TD></TR></TABLE>yes you are correct... my bad.
Re: which ecu to run with h22 civic swap without having to repin harness (turbogixxer)
if ur gonna get a hondata.. y not just get a p28.. they are the cheapest of the 3 rite...?...
Re: which ecu to run with h22 civic swap without having to repin harness (hondaZvic)
thats what i have decided to do, get a virgin and spend the extra green and get it programmed for my swap, thanx guys
