What axles or combination of axles to use for crx K series swap?
I have started the swap and rigged up some mounts,but cant finish placement until I get some axles in there and make sure theyre as straight as possible.Anybody have any ideas of which axle combinations I can use?Would the Hasport EG or EK K series axles work with in the crx?Would it be possible to use the rsx inners,gsr shafts and 90-93 integra outers?If I had all of those different axles laynig around Id most liekly figure out the axles myself,but axles are prett expensive and i dont have enough money to buy 3 sets of axles to rip apart.Thanks,
James
James
HT White Ops
Re: What axles or combination of axles to use for crx K series swap? (JDMotive)
You might have to show pics of engine placement before anyone can help you.
Re: What axles or combination of axles to use for crx K series swap? (rochesterricer)
The engine placement now isnt great..its just in there to get an idea of how everything is going to be.If I have to ill post pics as soon as the digi cam comes in from ebay,but im just trying to get an idea of what axles can be used.Like gsr shafts,rsx,shafts,prelude/accord shafts..etc...rsx inners,integra outers blah blah...any ideas?
HT White Ops
This thread might be of some help;
https://honda-tech.com/zerothread?id=924323
If you need more help, PM brian g or hybrid racing.
Edit: just noticed you posted in that thread.
Thanks...pm'd them both.Ill let you know what solution I end up with and ill post pics of the swap is Im doing it.
James
James
