need help with distributor g23 build
I was wondering if a f23 distributor will bolt up to a h22a head? another problem i have is i have an automatic tranny and im putting an h22 head on my f block and was wondering if i can use my stock ecu to run this g23 set up?
Re: need help with distributor g23 build
No go on the stock ecu, it will throw codes like a maniac. It will work, just not very well...
The dizzy is a no go as well. You would need a h22 dizzy. I dunno if you can modify (cut an ear) on the f23 dizzy to make it work though... =\
good luck
good luck
