Are EG and DC2 suspension arms/forks/knuckles/hubs 100% identical?
1 Post
I need to know if the suspension arms (upper A-arm, Knuckle, forks, LCA) are 100% the same between 92-95 Civic hatch and 94-01 Integra? I know that you can bolt the Integra suspension arms on the Civic's, but are the all the components virtually identical? Are there any differences or are the castings exactly the same? Are the arms/forks/knuckle/hub from one thicker or robust than the other in any way?
Could you for example use the upper and lower arms from one but combine them with the knuckle/hub and fork from the other to complete a set at one corner?
the reason I ask is that currently on my hatch I have the entire suspension (all arms, forks, knuckles, etc) from my wrecked Integra, but I think that one of the right front suspension components is slightly bent due to the fact that the alignment is completely off (and I know it's not a typical alignment issue).
Please inform if you know, thanks.
ILUVTEC
Suspension & Brakes
24
09-25-2012 02:11 PM
ILUVTEC
07-27-2009 04:26 AM
turboEFboy
10-09-2005 01:30 AM
