Quick B18C1 in to a Eg question.
Old Oct 4, 2009 | 01:46 PM
-16V-'s Avatar
Default Quick B18C1 in to a Eg question.
I swapped in a OBD-1 B18c1 full swap in my OBD-1 1994 Lx Eg.
Now im using a gsr engine harness, and stock civic ecu harness.
So i'm going to need to run wires up from the ecu for Vtec,Knock, IAB. Right? Since the stock civic harness has none of the stuff like a DOHC Vtec motor does.
Is there a way of re-pining these wires at the ecu to the shock towers for a cleaner look? Like swapping them around at the ecu plug?
TIA.
Old Oct 6, 2009 | 01:41 AM
93ekg23's Avatar
Default Re: Quick B18C1 in to a Eg question.
where there is a will there is a way. if u really wanna go through the hassle of that go for it. on mine i just pinned in at the plug for the ecu with clips from another plug and ran the wires out the fire wall and put that cheap bacl crinkle sleeving over it with a few black zip ties, looks decent. and it wont draw attention to it.
reygab123
Sep 2, 2017 11:30 AM
driftam1
Apr 25, 2008 09:13 AM
badb16rex
Apr 28, 2007 12:08 PM
StolenTeg
Aug 22, 2006 07:23 PM
civc_tt
Aug 16, 2006 02:37 AM
