GSR head w/ which block ??
Ok so i have gsr swap had some block issues so im getting a new block which would be better for pwr wise between b18c5 usdm block or a b18b1 block ?
Also is if i run ls vtec with the ls block im thinking itr pistons ,gsr wp and oil pump...good idea ???
Re: GSR head w/ which block ??
sounds good to me, I've always been partial to ls/vtec motors. when building a ls/vtec always match your wp with whatever timing belt you use because the tooth counts are different
