Integra turbo 4wd: The project start
I will start my 4WD project in a couples of weeks so I will share my project with you.
On the begining I was suposed to use crv trailing arm but after some comparisons and mesurements I have bought wagovan ones.
This is why. The crv need to much modification to fit and I need an OEM look so its not possible with these.
This is the wagovan, they're about 1.5 inch to long, the upper control arm a little bit to high and the lower is a little bit backward but its not a trouble I will just bolt my crossmember in consequence.
Rear diff and 2 short crv axles
Inspection of the rear diff, this one is bad so I have exchanged it
The viscous coupler and the pump/cylinder
Comparison of a D series diff and the crv diff
It will not fit but I find a subaru R160 diff and the interne seem similar so I will fit a Phantom Grip with upgrade spring
This is the wagovan crossmember under the DC.
Impressive that it will fit better than I was thinking
In the next weeks I will fit a civic hatchback spare tire floor to get more room for the diff and gas tank.
Updates to come
Updates to come
Re: Integra turbo 4wd: The project start
nice project!
i'm making a similar project with an EG6 and a H22 engine.
https://honda-tech.com/forums/showth...3#post39336173
Trailing arm are shortened. Need some weld filling and to smooth the surface and will look stock.
here is my eg6 AWD project almost done with videos and pics.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/check-out-my-awd-civic-eg6-2618576/
Accident Prone
1 Post
let's hope he wasnt lazy and has documentation somewhere; this is something i hope to do as an alternative to trying to custom fab an f20c w/ RWD into an integra. with this method this guy is doing, i can keep the B18 and still have 4wd
Steven.
08-01-2008 07:49 PM
