h23/h22
h23/h22
anyone have any problems out of the h23/h22 frank motor I have one thinking about putting in my eg it is mounted to a h23 trans. Do you think that would be better than my gsr i have now?
Re: h23/h22
We have one in our track car there really pretty good if built right we went through two blocks before we found a combo that worked. theres alot of mixed reviews out there about them but if you use bum parts you dont get a reliable product. If you do decide to build one be sure to add oil squirters alot of people lock up these motors because when tec hits it starves the bottom end of oil. like i said if done right there bad a$$ our is fully built puttin down 686whp on 27psi. GL hope i helped
Re: h23/h22
you have to get them off an H22 or I think there like 50 bucks from honda. If yours using the H23 block they just bolt it although I believe you have to take the crank out and then you have bend them so they dont hit anything
