delete moved to tech
Old Sep 29, 2009 | 06:06 PM
slowlsek's Avatar
Default delete moved to tech
first things first i've done numerous swaps and searched for the past week and still cant find my problem, this being said heres the deal.
00 USDM ITR swap into 00 civic ex. attempting to get it to run on stock sohc ECU. (the 00ITR ecu has a immoblizer in it hindering it to get fuel and spark. The sohc ecu will not be used to run the car just temporarily while im waiting on jumperharness and obd1 ecu. no the less the stock ecu should still let the engine fire.
i did the small dizzy plug to larger 96-98 dizzy plug swap. Correct way(depined not hacked) via katmans wiring diagram. also checked my wiring on a friends 00 SI all colors and locations are correct. as long as its the same as a SI...
last week: engine cranks but no fire. Pulled a plug checked for spark, i have none.
tonight i was going over all grounds wiring on dizzy and so forth and noticed the thermostat ground was not on (friend hooked it up while i was preping bay. he had it on a bracket but not on the thermo housing. so i changed over to the thermo housing, had the wife crank the car while i looked for spark....nothing....har her do it again and after about the fifth revalution i saw one faint fire from the plug. then it was gone. figured it was in my dizzy wiring not haveing the pins all the in. so i depined it and put the leads directly on to the dizzy pins( none were touching at all) ...still nothing.... im now offically stumped...i've been out of the honda game for two years and im hoping someone might post something that will jog my memory on a plug or a something that i forgot...please help its killing me to have a ITR in my garage and not able to drive it....
scoker83
May 3, 2014 10:16 PM
slowlsek
Nov 24, 2009 08:23 PM
Tippyman
15
Mar 28, 2006 10:18 AM
bluesi00
Jun 8, 2004 08:18 AM
Norcalstoppy
Aug 16, 2002 10:32 PM
