ARP head bolt stripped...
I have 96 gsr head on a 94 ls block trying to remove head and 1 arp head stud bolt is stripped what would u recomend to get the bolt off....
please respond asap i need to take my head OFFF
Re: ARP head bolt stripped...
i have tried the bolt off from craftsman as well as a couple other products but the head stud is a lil too deep to grab the nut all my other bolts are off the studs exept one some please give me some info
no Kragens around my area and they do have a stud removal set at autozone but the bolt is still on the stud, would the stud remover still work if the bolt is on, didnt want to try and chisel off the bolt cause im scared of damaging the head thanks for your help if n e one has n e other ideas please help its really pissing me off...
please nobody got n e more ideas i am str8 stuck like idk wtf to do i know some1 got a trick to get that bolt off the stud or take the hole stud at once pleasssee
its bolt threads are stripped or the nut is rounded? have you tried to use the allen socket on top of the bolt (if the nut is rounded)
tensaiwung
27
03-28-2012 10:02 AM
