CRV Swap???
Old Jul 28, 2009 | 11:44 AM
NSXRguy's Avatar
Default CRV Swap???
i have a simple question
is it possible to take out the b20b from a 98 crv awd manual, and swap in a built b18 long block in its place? will the crv tranny bolt on the b18 block with no problem???
Old Jul 28, 2009 | 01:11 PM
RyanA's Avatar
Default Re: CRV Swap???
Yes, it will bolt right in.
Old Jul 30, 2009 | 05:06 PM
NSXRguy's Avatar
what motor mounts will be needed? motor is b18 block
another question
how complicated would it be to get rid of the awd for a fwd conversion to use a b16 tranny? what kind of axles will i need? honda oem or has to be custom?
Old Jul 30, 2009 | 05:19 PM
GSaura's Avatar
What is your project? What are you trying to do?
If you have a crv, use the stock crv mounts. I don't think they make aftermarket ones. As far as eliminating AWD, I don't see why it would be difficult at all (but I have no first hand experience). Remove axles and rear end then you're done.
Old Jul 30, 2009 | 10:14 PM
88ED8's Avatar
Originally Posted by NSXRguy
how complicated would it be to get rid of the awd?
Not complicated at all, You will probly have to make a custom passenger side mount bracket as the awd trans uses a different bolt patteren than a fwd trans, a fwd rear "T" bracket should fit right in (not shure from what model you'll need it from) and you'll need to mount a convenional fwd shifter in the floor.
If you get rid of the:
AWD 5spd transmission
shifter & shift cables
drive shaft
rear differential
lmk!
Old Jul 31, 2009 | 10:25 PM
Jaker's Avatar
The CRV RT4WD transmission will work just fine as a FWD transmission without resorting to anything fancy. All you need to do is remove the driveshaft, the rear diff and almost all of the rear axles. You'll need to keep the outer joints of the rear axles bolted into the rear hubs, as that is what holds the hubs/bearings together and that is where your wheel speed sensor rings are mounted.
Your B18 will bolt into the CRV using your existing CRV motor mounts.
Old Aug 1, 2009 | 12:02 AM
88ED8's Avatar
but he wants a b16 tranny yo!
Crayola Nugget
Jan 29, 2019 05:00 PM
anthcrx
Jun 2, 2010 12:15 PM
NSXRguy
24
Sep 26, 2009 02:27 PM
fOmaNPu
Mar 21, 2003 07:56 AM
fOmaNPu
Mar 20, 2003 06:22 PM
