some people
Old Aug 30, 2009 | 06:44 PM
tjus313's Avatar
Default some people
okay guys heres one for ya. this kid brings me a 1996 hatch dx and says "i cracked my block, can u fix this for me?" i said sure...not a problem. hes running a b16 with hydro tranny stock bottom end and build motor on 38lbs of boost fix the block and its all good. he calls me a couple days later and says "my car started to spit and spudder and wont start now" i tow the car back to the shop and i come up with this....there are 100000000000 plugs not plugged into anything and dont have a home. there is only one sensor pluged in on the entire motor.....pulled the ecu.....you should see this mess....wires everywhere...looked like it was piggybacked and its a flashed ecu with no stickers...PLEASE HELP ME before i pull my damn hair out lol...oh and i looked at it a bit ago and noticed that there were 2 hot wires on the cap only when the ignition is on?!? what could cause this if it was running perfect a few days before?
Old Aug 30, 2009 | 07:00 PM
88Hatchy's Avatar
Default Re: some people
english please...
Old Aug 30, 2009 | 07:08 PM
tjus313's Avatar
Originally Posted by 88Hatchy
english please...
okay to make a long story short, this kid blew a hole in his block from too much boost, i put a new spring in it so its only running 5 pounds now and fixed the block. it ran for a couple days and he called me saying that his car wont start, come fix it. so i towed it back to the garage and noticed that there are wires everwhere and i have no idea where they go and the coil is throwing hot from both sides and wont fire.
Old Aug 30, 2009 | 07:52 PM
nemisish20's Avatar
Wheres my titleeeee!
u fixed the block?
Old Aug 30, 2009 | 08:11 PM
tjus313's Avatar
Originally Posted by nemisish20
u fixed the block?
yes sir, new block
Old Aug 30, 2009 | 08:19 PM
tjus313's Avatar
here is what i figured out on the car so far: story goes like this....
the car was purchased brand new from an older gentlemen in New Jersey
1996 Honda Civic dx (automatic)
sold the car a few years later to this kid
the kid starting moding the car, eventually converting it to a 5 speed
B16A1 with a hydro tranny
then along came the turbo
first 10lbs....then 20...then the high boost
cracked the block, i replaced it and rebuild the motor to handle some boost, set the boost down to 5lbs using a spring.
the guy added a vtec controller and thats where **** started going wrong (this is how i take it)
i mean its a really clean motor and all, the swap was done well and i know there will be some plugs left over when doing a swap but this car is a wireing mess. the guy that owns the car is the kind of person that has more money then brains....he would rather get a polished intake mani spacer rather then getting a hondata computer that would acutally be programmed for his ride other then the flashed ecu hes using now. ill post some pics of it when i can find them
Old Aug 30, 2009 | 08:32 PM
tjus313's Avatar
[ATTACH][ATTACH][ATTACH][ATTACH]Name:  c5.jpg
Size:  53.6 KB[/ATTACH][/ATTACH][/ATTACH][/ATTACH]
Old Aug 30, 2009 | 08:35 PM
tjus313's Avatar
Old Aug 30, 2009 | 08:36 PM
tjus313's Avatar
theres a few of the before and after the split, cant seem to find any of the wireing and all, ill have to take some later
Old Aug 30, 2009 | 09:15 PM
tjus313's Avatar
any idea why it would be throwing spark to both sides of the coil pack?
Old Aug 31, 2009 | 01:19 AM
Integra4lyfe069's Avatar
whats with the screw driver stuck in the back lols.
Old Aug 31, 2009 | 02:00 PM
88Hatchy's Avatar
If the engine ran fine when it left, I would charge the guy for returning everything back to the way you had it. Then charge to add whatever he had attempted to add.
Old Sep 1, 2009 | 01:12 PM
tjus313's Avatar
well he is getting charged for bringing the car back, its an entirely new problem. but that still isnt answering my question about the coil pack, why is there 2 hots now?
Old Sep 7, 2009 | 05:52 PM
93grayeg's Avatar
This is chucks car . he bought it from a mexican in NJ . . chuck did nothing to this car besides blow it up . . .that thing is a mess.
Old Sep 8, 2009 | 03:37 AM
tjus313's Avatar
andyboy
Mar 29, 2006 07:58 AM
turbotime
Oct 3, 2005 05:59 PM
shadowstylz
Oct 12, 2003 10:26 AM
AMG
Aug 15, 2003 06:46 AM
