H22A4-F22/H23 crank and rod ???
Ok so for the past two days straight i have been searching and reading all about this subect of swaping an F22/H23 crank and rods in the H22 for the increased stroke.
I have a 98 BB6 with the H22A4 of course now someone said that starting in 98 the main journals are 55mm. Now I know that the F22 and H23 have 50mm main journals.
Now my question is are there any F22/H23 crank that might fit that does have 55mm mains maybe they had an update like the h22 of am I SOL and have to get an older style block? Or is there even another crank i could use that has the same 95mm stroke
Re: H22A4-F22/H23 crank and rod ???
so the f20b has a 95mm stroke with the 55mm mains?...I know the f23 has a 97mm stroke which i dont believe will work
That was why I am wanting another crank is for the 95mm stroke
