b18c1 intake manifold question
ok i have a stock oem gsr intake manifold with no fuel rail,and no t-body. my question is what all b seried rail,t-bodys are interchangeable for this task at hand. b18a/b?????
the this is i have a b16a3 in my ek now but i do not want 2 take the fuel rail,t-body off just 2 get my gsr ready. please lend a helping had. thanks ht
Re: b18c1 intake manifold question
to the best of my knowledge (which isnt much) a ls fuel rail and throttle body should work on your gsr, as long as both throttle bodies are 81mm i wouldnt see why not, and the fuel rail will work because if im not mistaken they are both 240cc but idk what kind of gas mileage youll be getting, im sure most wouldnt recommend it but if u need a quick fix. im basing this off an ls/vtec swap im working on, but also like i said im not the most or even close to best knowledgable its my first swap so i hope what im telling you is right! if not someone please by all means correct me, good luck man
CORRECTION...wow my bad i was way off dont know where the 81mm throttle body came from haha, guess my brain is stuck on this swap... i ran across this guide because i was curious myself, but i still dont know if the fact that itll bolt up means itll work for your gsr
Honda Throttle Body Sizing Chart
Inside Diameters (in mm)
d15b7 - 56
d16a6 - 55
d16y7 - 56
d16y8 - 56
d16z6 - 56
ZC - 55
d16a1 - 55
d16a8 - 55
b18c1 - 60
b18c5 - 62
b18a - 58
b18b - 60
b16a SiR - 58
b16a Sir2 - 60
b16a2 - 60
b16a3 - 60
b20b - 60
b20z - 60
h22a - 60
h23a - 60
f20c - 62
f22 - 60
f23 - 60
hope this helps!
d15b7 - 56
d16a6 - 55
d16y7 - 56
d16y8 - 56
d16z6 - 56
ZC - 55
d16a1 - 55
d16a8 - 55
b18c1 - 60
b18c5 - 62
b18a - 58
b18b - 60
b16a SiR - 58
b16a Sir2 - 60
b16a2 - 60
b16a3 - 60
b20b - 60
b20z - 60
h22a - 60
h23a - 60
f20c - 62
f22 - 60
f23 - 60
hope this helps!
Knogooseness
11-26-2013 08:13 PM
91lsteg
08-25-2009 10:02 PM
