obd2 gsr in eg fuel issues
ok i have a 95 civic cx with a obd2 gsr its all wired in but for some reason when i start it wont stay alive like it starts then dies, its trowing code 16 and 41, i know 41 is o2 dont worring about that but 16 is fuel system problems, how do i get rid of that code 16 is it possible to get that ground plug on the drivers side mixed up and it throw that code? if needed i can get pics
Re: obd2 gsr in eg fuel issues
I had the same problem with my last swap. I had fuel reaching the fuel rail because it start then dies. Pressure was ok, and there was 12V at the injectors=ecu send no ground to the injectors. I cranked the car for like 15-20 sec. then the ecu throw me a crank sensor code!! Fixed it and the car runs great now. Hope this will help
still have problems i got the code 16 to go away but still same problem ive gto no clue its gotta have spark and fuel since it starts for 1 to 3 secs, my guess maybe a bad ecu ground or not turing on? ecu is a p28 and all 3 grounds are good the t housing valve cover and trans i got them all could it be vacuum problems?
ok now it says the ecu is fried both of them (i got 2 p28s) i didnt even move anything all i did was verify everything on the ecu is there
ok update now all my check codes are gone, but when i plug the jumper in to check codes it shows a solid cel maybe its suppose to do that. anyway when i had my brother try to start it i put my whole hand over the Trottle body and it started and idled for like 5 secs whys that?
ok maybe something that might have an effect, im using a fuel rail and FPR off of a 4dr ls auto, pretty sure gsr and that one is the same but you never know
dsmarefaster
04-19-2005 04:59 PM
mike93eh
36
12-18-2004 01:18 PM
dreweg
08-01-2003 09:17 PM
bossman032
06-30-2003 04:30 PM
