OBD2b 99 ex wire harness PLUG DILEMA
hi guys
bought 99 ex wire harness while back and just got my conversion harness in to run obd 1
and it seems that these are the only three connections i have and i seem to be missing one
a small white or light greyish color / the harness looks virgin and i cant figure out if its just not the right harness or is this for auto instead of 5 spd like it supose to be.. any input would help me when i go try and get money back
thnks
thnks
Re: OBD2b 99 ex wire harness PLUG DILEMA
sry i just read what i posted last night and it might seem like the conversion harness is what im having trouble with but it is the actual wire harness .. the boomslang OBD1plugs directly into my ecu but the obd2 side both blue and gray plug in but the green/ i believe goes to chasis harness or dash and connects on top of ecu so there is one missing or no?...or is this for a different car ?
the other plug is on the dash harness
everything is good
96-98 engine harness have the 3 plugs on it
99-00 engine harness have 2 plugs on it and one on the dash harness
everything is good
except mine looks like the green plug above and the mystery plug that we discovered are on the same loom and the ex harness the green plug is on the loom with the (b and c >>from above)
so green is for my guage cluster and (A from above) is in my car for what? and im using a from my car into the wire conversion harness
ok i think i see eerything now.. the engine wire harness has b and c and the guague cluster green.. and the harness in the car has guage cluster connector and A plug... so i use the other piece from the car.. .i seee
plug a is for your engine
man your freaking out
you have nothing to worry about
http://ff-squad.com/technet/wiring.obd2b.htm
haha i was freaking out.. i thought everything was gonna go smoth once i got my conversion harness and the swap is going in on tuesday.. and i thought my wire harness was missing a plug.. and i was refrencing my buddys obd2 a setup so i thought there was suppose to be another plug on the wire harnes
you dont know how much you just saved me... i was going to go back return it and prob go to honda and spend *** amounts for a new one.. hahahaha im so glad we talked before!!!
id like to buy you a drink
