OBD2a engine/chassis, OBD1 ECU, which alternator?
As the title says, I'm running a b18b1 in a 96 EK hatchback, and I have the engine running, but I can't tell if either the alternator is dead, or I'm supposed to be using a different alternator. I'm using a P28 ECU with Hondata, so do I have to convert to an OBD1 alternator or what?
I'm sorry if this has been covered many times, I can't seem to find the exact infomation on this subject.
Thanks,
- Steven
Thanks,
- Steven
Re: OBD2a engine/chassis, OBD1 ECU, which alternator?
It's an OBD2a engine harness. I heard the OBD2 alternators have a different voltage regulator in them though, so I don't know if that is why the battery isn't getting a charge or what.
update: went and had the alternator tested, it's making an average of 14.7 volts, so it's good. The harness is obd2a, engine is obd2a, ecu is obd1...I guess either I have a connectivity or grounding problem, or I have to change to an obd1 alternator.
Ok thank you for eliminating that out of the equation. I'll start trying to track down the connection or grounding problem this week.
Uniquerootz
10-02-2007 11:40 AM
RACEPAK
09-07-2006 10:22 PM
gezer
09-03-2004 05:17 PM
