F20B dizzy wiring
Old Jul 25, 2009 | 02:52 AM
f20bcl's Avatar
Default F20B dizzy wiring
f20b going into a 97 cl. i used the cl harness which most plugs r plug n play...except for the dizzy. now on the f22b(CL) dizzy i see that the RPM signal is connected to the blue wire. theres is nothing connected on the f20b, so of course you have to add a wire on the empty blade and im guessing connecting it to the blue wire also? sum ppl say to ground..but idk.
other than that...i have color matched all 5 wires from the cl harness to the 5 on the f20b dizzy,
but f20b has a 8pin plug, which leaves me with 3 extra wires(white/blue, yellow/blue &white)...where do i connect these to..or do i just ignore them?
i believe the 2 wires( whit/blu & yell/blu) are the +/- TDC(top dead sensor)
help me please!!!!
p.s. -if you guys want pics i can try n post if it will help.
Old Jul 26, 2009 | 08:31 AM
f20bcl's Avatar
Default Re: F20B dizzy wiring
here is where i am at....where do the extra three wires go?
Old Jul 23, 2010 | 07:55 AM
AllMadd's Avatar
Did you happen to fig it out?
Im bout to do the same swap.....what trany are you using? f20?
neverenoughx2
Aug 6, 2018 11:32 AM
simplypinoyy
Jul 13, 2008 03:23 PM
TurboGoKart
20
Apr 10, 2007 11:51 AM
DEL HATCH
Aug 29, 2006 06:23 AM
I8ayellowcrayon
May 24, 2004 08:21 PM
