HCP h22 a/c mount bracket...what is it that i need to relocate? (i forget)
i'm trying to remember what i need to relocate so i can have it done before i order all my parts. can someone help me out?
Re: HCP h22 a/c mount bracket...what is it that i need to relocate? (heiyu)
umm....how would i go about doing that? the a/c fan is like 6" thick.
Re: HCP h22 a/c mount bracket...what is it that i need to relocate? (hot_EF)
you are gonna have to run a slimmer fan for this swap as with all h22 swaps into civics, also with your gen, i think you have to wire the fan to flow the other way, but don't qoute me on it. You should IM a guy named Prospeed, he sells these kits and can tell you what's up.
Re: HCP h22 a/c mount bracket...what is it that i need to relocate? (SilverCivic2k)
how much is that bracket anyways? I was thinking of just machining my own.. do you know where it relocates the compressor? does it just put it in line with the alternator belt?
Re: HCP h22 a/c mount bracket...what is it that i need to relocate? (H22AMedina)
it's $175 and it has it's own belt that comes with it...i don't know what pulley set it runs off of though...
As for PS, there's no way it'll work. The pulley sits behind the frame rail and will not clear.
Re: HCP h22 a/c mount bracket...what is it that i need to relocate? (Newman)
what won't work? machining my own? do you have pics of it yet? What pulley is it running compressor with? on an EK btw
I still don't understand why people say the powersteering won't work... I left it on the motor dropped it in everything fit, i trimmed the back of the headlight housing slightly to give some room for the hose off the bottom of the PS pump... the belt is close but it has about 1/8" clearence on the frame rail. I got a prelude fitting spliced onto the end of my civic PS line and bam away i went. I'm getting tired of hearing people everywhere say it doesn't fit.
Re: HCP h22 a/c mount bracket...what is it that i need to relocate? (Alstare)
do you have PS AND A/C? that's fawking awesome if you do. i've always heard, and well, from the pictures i've seen, it's like there's room for one or the other..but not both. and i personally would rather have a/c over PS as PS SUCKS a nut. the steering wheel feels like play-do with it
I have AC but I used the prelude compressor with a CRX condensor inside the bumper, and a slim fan (I forgot the brand) customs lines and fittings. Work like a charm. As far as power steering, Who needs that anyway work those arm muscle.
