is a gsr head better den b16 head on a stock b16a motor
i have a gsr head on my jdm b16a block but i havent put the motor in yet but i wanan know if its better den stock b16a head.....has ne one done this is swap???if so can i see some dyno sheets of hp....cause all i know is gsr has lower compression ratio...and that make more hp...thanks
Re: is a gsr head better den b16 head on a stock b16a motor (JoHn CoNrOe)
it will be slower than it would with the standard head.
lower compression does not make you faster.
i hope ur not serious.
i think what i said is right.....feel free to back me up anyone
Re: is a gsr head better den b16 head on a stock b16a motor (ben_vtec)
haha
lower compression=less hp dude
the gsr head flows about 15% worse than the b16 head
stick with the b16.
stick with the b16.
keep talkin like that newbie and your stay here will be shorter then your bobby ***.
Anyway... I'd do the GSR head for the compression. Although its only a bit.. I'd rather have higher compression then better flow. I'd only stay with the B16 if your going to upgrade the IM, TB, or cams to utilize that flow.
Re: is a gsr head better den b16 head on a stock b16a motor (CRX_VTEC)
just one tip , dont run single layer head gasket with the GSR other wise you will have clearence issues .
from stock to stock gsr will make more CR
but b16 will flow better
p&p is a hold different thing
i meant higher compression dick face
dumbass newbie dont get a ******* attitude, nobody will help you.
[Modified by KAMiN, 3:43 AM 6/30/2002]
spoon95eg
02-26-2006 01:16 PM
