b16 in 92 vx teg axles and linkage?
Can you use integra axles with a jdm SIRII b16 swap or do you have to use del sol vtec axles? The only thing i'm unsure about would be the int. shaft being where you can't use teg axles.
Also you can use del sol vtec and 94-up teg shift linkage as well as 99-up si linkage right?
Thanks
Thanks
Re: b16 in 92 vx teg axles and linkage? (nsxmatt)
axles you want are from any 2nd gen b series, like integra 94+ or del sol vtec or 99-00 si
shift linkage, I am NOT sure if 99-00 si or del sol vtec linkage will work.
-->I DO know that 94+ teg shift linkage WILL work<--
Re: b16 in 92 vx teg axles and linkage? (owen_the_soyboy)
Sounds good, I was unsure on the axles and since i'm gonna just get some from advanced or something with a lifetime warranty Thanks for your help!!!
Anyone else care to share their thoughts on the linkage?
Re: b16 in 92 vx teg axles and linkage? (spAdam)
I still hear conflicting opinions on the axles. Some people say because of the int. shaft i'll have to use del sol axles. True or not?
Also what radiator hoses will I need? Del sol vtec top and bottom?
I'm thinking about getting a b16a1 longblock for my 92 integra. I'll keep the ls tranny. The only issue I see is whether the intermediate shaft mounts in the exact same spot on both blocks. If it does I'll be able to use my axles. The longblock is only $450, doesn't make much sense to get a full swap ($1250).
tealsvteceg
02-25-2008 08:06 PM
nomotorsol
12-28-2004 06:20 AM
RedDelSol si
10-01-2003 04:42 PM
