Knock sensor...96 B18C1 into 95 EX
This is one of the final things that needs to be done so I can finally run this beast. Where do I find the wire on the engine....and where does it plug into on the ecu? I'm confused on this! Help!!
TIA
TIA
Re: Knock sensor...96 B18C1 into 95 EX (Thagreybomber)
it's on the back of the block above the oil filter right on the top and center, what ecu are you using?
Re: Knock sensor...96 B18C1 into 95 EX (dohcsideSi)
I'm using a 95 Geeser ECU. So the wire is above the oil filter, or the one right next to the oil filter? Is it the one with a green plug and only one wire coming out? What color is it, and where do i put the wire into...Pin number?
[Modified by Thagreybomber, 10:51 PM 6/29/2002]
Re: Knock sensor...96 B18C1 into 95 EX (dose)
i don't remember the site...but you can do a search on Google.com and type hybrid honda. Hope you find it
click this link for the big picture:
http://www.imagestation.com/picture/...8.jpg.orig.jpg
might have to cut and paste......
