gsr tranny and block into coupe
Im looking for all the info I can get on transplanting a obd2 gsr engine and tranny into a 92-00 civic coupe. I've read pages of archives, searched specific questions and look through a few walkthroughs.... Im just looking for any and all extra web links, book recommendations, etc... To ensure a flawless install when the time arises, thanks ahead of time.
Re: gsr tranny and block into coupe (KAMiN)
im leaning more towards 92-95 but haven't heard much difference between the two. Hence the reason why im looking for information on both to finalise my choice.
Re: gsr tranny and block into coupe (Tired)
The obdII swap will plug right into the underhood harnesses (if you get the OBDII wiring harness with the motor). You may have to add the VTEC wiring depending on year and model.
In order to keep it all plug and play. You can run either a chipped P28 or an OBDI P72 ECU.
Check the link for more info....... 5th gen Hybrids
[Modified by JV, 11:37 PM 7/7/2002]
[Modified by JV, 11:39 PM 7/7/2002]
BradleyJP
05-17-2009 03:30 PM
ceamodt
04-04-2006 01:30 AM
