Thinking of doing an lsvtec swap....what should i look out for?
lsvtec swaps are usually done with the b20 block. what are the most common problems with this swap?
how about an lsvtec swap with a b21 block? what would be the common problems with this? or would it be pretty much identical?
any help would be much appreciated!
Re: Thinking of doing an lsvtec swap....what should i look out for? (irdprelude)
LS/VTEC's use the b18 block, CR-VTEC runs the b20 bottom end....
Re: Thinking of doing an lsvtec swap....what should i look out for? (sappsycho)
ok...so its the cr-vtec swap i am looking at...if i have a b21a1 block will it make a difference in the swap?
should i buy the b20 block? should i keep my b21 block? has anyone done a crvtec swap with a b21?
i am pretty lost on the subject if you cant tell...lol
if you do a crvtec you will have to do a complete motor swap since your motor leans forward and other engines have a more straight forward stance.
Re: Thinking of doing an lsvtec swap....what should i look out for? (infamousRRH)
the b21 is a piece of **** period. stay far away from it....i won't go into it but it's right up there with the 12 valve accord motors.
Re: Thinking of doing an lsvtec swap....what should i look out for? (dohcsideSi)
so whats the difference between the b21 and the b20? what makes the b20 better?
how about the b20a5 for a replacement for the b21?
chris just do a h22 cheap as ls vtec is going to cost and more torque... $2400 for the complete swap
alien
05-30-2006 09:43 PM
tfalconier
07-18-2004 09:31 PM
