best camshaft for a jdm b16a1??
i wana get skunk2 stage 3 cams. any other good ones out there before i go along with skun2?? also how much would they be?
[Modified by GsRHaTch, 10:22 PM 7/2/2002]
Re: best camshaft for a jdm b16a1?? (GsRHaTch)
If it's for the street...i'd recommend going with the stage 2s. I believe all the skunk cams are in the neighborhood of $700-750. Look to upgrade ur valvetrain with stage 2s.
The stage 2's are pretty much identical to JUN3s. That'll probably tell you how much of a pure race cam stage 3s are then. Good luck on ur choice!
-Rod
-Rod
itr set cheap and reliable, work well....
not dynoed yet but enough to take my 91 EX (>2570 lb. with me in it) to 13.98 @99.41 with 1.80 60 ft. best......
I have a skunk 2 stage 1 cam on my GSR engine.
One thing I notice is the dips when vtec engages and IAB opens.
U feel them when driving on the highway specially when the speed is broderline vtec-off and on and u keep transitioning in and out.
To be honest, its really annoying. I think its because the lobe difference between the 2 profiles is big that the engine looses intake air velocity.
Re: best camshaft for a jdm b16a1?? (johnd)
Re: best camshaft for a jdm b16a1?? (RK)
Yes the cams have been tuned. The best so far is +1 intake and +1 exhaust.
Dip is still there, not as bad but still annoying on the transition.
The good part is after the dip, u really feel the surge from 6,000-8500 rpms.
Some say use VAFC to mask the dip. I believe it could help but not eliminate as the lobe difference is big enough to alter intake and exhaust velocity momentarily.
In the end, it was a choice between really stong torque and HP in the low revs then big dip then back on power VERSUS Slightly milder low revs, unoticable dip then power surge.
I chose the dip with stong low. I'll just try to avoid cruising borderline vtec.
