OBD 1 LS ECU........
Old Jul 8, 2002 | 08:27 AM
DR. ON POINT's Avatar
Banned
Default OBD 1 LS ECU........
Is there a difference between the 92-93 ECU's and the 94-95 ECU's?
Also what is the code for this ECU PR4?
Old Jul 8, 2002 | 08:38 AM
under_psi's Avatar
Default Re: OBD 1 LS ECU........ (On Point EK!!!!!!!!)
94-95 integra non-vtec 5spd is P75
Old Jul 8, 2002 | 09:13 AM
eg6ajk's Avatar
the boards are slightly different but no actual difference in performance
92-3 ECUs are PR4 (just watch out as 90-1 non-obd ecus are also PR4)
94-5 ECUs come in P75 and in some cases P74
if the code: 37820-P75-A51
the 5 in the third set of numbers means that the ecu is auto
[Modified by eg6ajk, 12:14 PM 7/8/2002]
Old Jul 8, 2002 | 11:20 AM
Banned
Default Re: OBD 1 LS ECU........ (eg6ajk)
Thanks a lot guys.
Old Jul 9, 2002 | 09:13 AM
g_man80's Avatar
Check out this site:
http://hazone.com/default.htm?ecu.htm
Also: 92-95 ls/gs is P74 or P75. Like eg6ajk said it's the same performance wise. The difference is the way it mounts in behind the dash and carpet (the 92,93 is different from the 94,95). If it's going in an EG is would suggest the P75 from a 94 or 95. The PR4 ended after '91.
Old Jul 9, 2002 | 02:15 PM
Banned
Default Re: OBD 1 LS ECU........ (g_man80)
Its actly going in a EK. Oh well I have duct tape and zip ties.
endlesswinterco
Jan 5, 2005 08:33 AM
series3racer19
Dec 7, 2004 03:13 PM
BLUE EH3
Oct 31, 2003 08:59 AM
OnePointFive
May 1, 2003 08:04 PM
Honda4CX-T
Feb 21, 2002 03:58 PM
