knock sensor question
Old Jul 1, 2002 | 01:56 PM
memphiss13's Avatar
Default knock sensor question
ok i had all my codes gone and everything was fixed, then i was driving and the CEL came on again. it turned out to be the knock sensor throwing a code. so i go home and check everything and its all hooked up fine. drive around for about five minutes and it pops on again. this has been going on for the last two days, its been off and on. but everything works fine. it still goes into VTEC and everything. the question is, is this hurting performance at all? does the knock sensor throwing a code make it go into limp mode. its not on when i start the car and its not on when i turn the key on. it only comes on after i drive for a few minutes. whats going on?
Old Jul 1, 2002 | 02:28 PM
B_CRUZ!'s Avatar
Default Re: knock sensor question (rookie2nr)
maybe it is detecting knock ?
Old Jul 1, 2002 | 03:35 PM
memphiss13's Avatar
Default Re: knock sensor question (B_Cruz)
thats not good
memphiss13's Avatar
can someone explain exactly what knock is
Old Jul 1, 2002 | 04:05 PM
JD_B18CDX's Avatar
Knock Sensor = a piezoelectric microphone that is especially tuned to pickup engine vibrations created by knock (also called detonation or ping). The sensor has a 3/8" NPT thread for attachment to the engine block or cylinder head. Above approximately 5000 rpm, however, this knock may be masked by mechanical noise and is disabled.
shoklid
Sep 6, 2009 04:58 PM
SpoonFedEj8
Dec 23, 2008 03:11 PM
KleenL
Nov 25, 2007 05:57 PM
co_OlLo_OdDo_Od
May 3, 2006 11:36 PM
Under_Pressure
Oct 4, 2005 12:38 PM
