head swap b-18b1 block w/b16a head
?head swap b-18b1 block w/b16a head
what kind of tunning do i need to do to make this swap clean and nice running? any thing you can tell me about this swap will help me out i just want it to turn out the best it can.
thanks much
[Modified by 95orangeciviccup, 10:44 PM 7/5/2002]
thanks much
Re: ?head swap b-18b1 block w/b16a head (95orangeciviccup)
dont have the conversion done in a shitbox place. do it right the first time. i have heard about valve relief, use vtec pistons, because ls pistons are rumored to hit the head and valves. do not use b16a(1st gen) valvetrain parts, theyre too old.
Re: ?head swap b-18b1 block w/b16a head (JDM Dasilva)
Worked for me. Just make sure tge oil line to the VTEC solenoid is atleast -4 AN. We tried -3 (unknowingly) and VTEC would not come on till 6000. I have not taken the head off the look for valve clearance, but I drove it 1200 miles from Los Angeles to Seattle with no problems.
ERIC 87 GN 91 Integra.
If you are looking for other sources than here for LSVTEC info go here: http://www.geocities.com/lpardini3/. It has links to other LSVTEC sites. HTH...
