JDM type R into my 89 si hatch
hey guys i got my jdm type r setup and i am planin on puttin it in my 89 si hatch, before i go abou tthi sprocess , just wanted to see if anyone else out there has this setup i wanted to get there feedback from them , what problems i will come accross and what to look for or anythign that helped you , please let me knowthanks
email groovinmind@yahoo.com if you wanna be realyl nice! thanks
bryon
bye
bryon
bye
Re: JDM type R into my 89 si hatch (groovinmind)
there are a few issues you will have to deal with:
Tranny-to use the Type R tranny (a hydraulic tranny) you would have to replace your clutch pedal and assembly with a hydraulic setup (from any civic or teg 94 and up). this will require some ingenuity and custom work but i've seen it done. Otherwise, any cable b-series tranny will work (look for S1, J1, or even a YS1).
Wiring-the type R motor is OBD 2 and your car is OBD 0. One way to deal with this is to use all of the wiring from the ITR, including fuse boxes and such. Then your car would be running on the old wiring but your motor would run on the new wiring. Or you could convert the engine to OBD 0 by changing the distributor, injectors, etc (pain in the ***). talk to blownhatch in the EF forum if you go for the second choice.
Mounts-if you use a cable tranny, any of the mount kits will work. if you use the Type R tranny, use the HCP kit. The rear and drivers side mounts will bolt up perfect. The tranny side mount will need a little modification.
Good luck.
Good luck.
Re: JDM type R into my 89 si hatch (red civic standard)
your best bet IMHO would be to get a 92 + civic, it would be alot easier on you. But good luck either way.
