need hybrid guru to help with H22 problem
Ok guys here goes...
91 accord h22 motor & tranny/ Accord axles...
motor has been in since Oct. running fine...now getting a humming sound from where the driverside cv axle meets the intermediate shaft on back of the motor...bad shaft bearing? bad cv joint? replaced both axles and shaft but still same problem! appears the cv joint is binding up like the axle is too long or its not lining up correctly.. but I used geniune honda accord parts from the dealer...HMMMM?????? dont know!! One suggestion has been possibly a bad driver side motor mount causing misalignment ..... has anyone else had this or similar problem with their Acclude or other hybrid????
[Modified by BIG ROB, 4:25 PM 6/28/2002]
Re: need hybrid guru to help with H22 problem (BIG ROB)
Need some information first. What axles are you using? Which intermediate shaft are you using? And yes if your mounts are bad they will put excessive wear on your axles. Had a friend of mines with bad mounts on his old celica and the axles would pop out of the tranny side all the time because of this..
Re: need hybrid guru to help with H22 problem (Jason kiDD)
Thanks for answering!! Im using the Accord axles and shaft..just replaced all of them with new parts last week and car is back in the garage... I will replace the motor mounts and see if that does it! Your the third person to mention the mounts so I hope Ive found my problem... May even try the polyurethane inserts too and see if how it drives.... Thanks again!!
TH22A1
03-20-2010 08:24 PM
PotatoePAPA
03-31-2003 01:14 PM
