do you think I will have any sealing issues with 86mm...
I will order a cometic gasket and us arp head studs but I wonder if it will seal properly, the sleeves where put in by golden eagle.
Re: do you think I will have any sealing issues with 86mm... (infamousRRH)
i think you'll be fine, cause i'm running 85mm w/cometic gasket, and i've only heard good things!
vnt
vnt
Re: do you think I will have any sealing issues with 86mm... (vntperformance)
thank you vtnperformance... question for you what are the specs on your gasket tha you had cometic make... could you help me on that?
