B18 Idle issues
Car runs great when cold, about 1100 rpm, but once warmed up it bounces from 950 to 400 car is still drivable, but its kinda freaking me out..
Things I have done
Replace TPS
Cleaned IACV
Note: The guy who did the swap in the Del Sol, doesn't have the coolant lines hooked up to the IACV, could this be the reason? Or could this be a simple ECU reflash, which I know it needs..
But he has also bypassed alot of stuff. Like no heater gutted, radiator goes to motor, motor to radiator.. No where else
Things I have done
Replace TPS
Cleaned IACV
Go to auto zone and get a free OBD scan on your CEL and pull the codes. Come back with the codes and good which each one is and go from there. you also said the coolant lines to the IACV is disconnected? Connect them lol
About that.. I believe I have some lines missing to plug those back up, not sure yet..
Yea, its been a headache, I traded for the car, already built by someone else, so I am having to go over it with a fine tooth comb.. Which I know the ecu needs re-tuned cause previous owner had a 6262 80ar turbo on it, but got low on funds sold it and put a 50 trim on it... So the fuel/air is slightly off..
No, I am waiting on my Usb to OBD cable to come in, so I can reflash it.. Its already tuned with Crome, which I now have on my laptop. Just need my cable.
Which when I unplugged the batt to install the tps, I believe I screwed up the tune worse, cause even my RPMs are off 55mph 3700 rpm in 5th lol
I can think of a few diff things could be wrong could be from swapping out stuff like turbo an need to remap your fuel maps.
like turbo,injectors
Check your timing and also check your valve lash
It could also be for fitv try cleaning that out
But first try to clean your fitv
MWLW20
Oct 2, 2009 10:46 AM
skunkcoupe
11
Mar 28, 2007 07:34 AM
