CRX SI B18A1 Distributor question
I drove this car with a hacked wiretuck job the PO did and it almost caught fire . Well I have all new harnesses in and my ecu jumper, I'm stuck on rewiring the Distributor he cut the plugs and straight wired it. It's a td86u on a obd1 swap B18a1. Anyone care to show me how to wire this up to my SI harness? Thanks in advance!
Re: CRX SI B18A1 Distributor question
The ecu is obd1 with a jumper. The distributor is obd2 according to wiki. The car ran with this dist ecu combo already I drove it like this for awhile, he just had the plugs cut and wired.
So now I am completely confused... I got the dizzy wired up and it wouldnt start just cranks over.
I have a obd2 Dizzy,Obd1 ECU and Obd1 Injectors.... This car ran with the old hacked wiring harness with these parts and no resistor box. Only thing I can think of is I may have wired the dizz wrong. All grounds are good as well.
Update, checked for spark and I have it so I shot a tiny bit of ether into the intake and bam it started for a few seconds and died. I can hear my fuel pump so i'm guessing injectors? [IMG][/IMG]
This is the green plug that is supposed to go to the resistor. But im using obd1 injectors so I was told to splice them together.
Took off my jumper harness and plugged my obd0 ecu in, car fired right up but of course ran like crap bein everything else is obd1. Now just tryin to hunt down a wire pinout for my ecu jumper.
hey im sorry i didnt get a chance to get to my garage yesterday but i dont recal splicing anythign on my resistor box when switching to obd0 im pretty sure u just leave it alone. and my cars been runnin just fine for 5 years now. and i will still get u that diagram soon i should be over there tomarow
Adam West
05-08-2006 03:47 AM
