Comfused plz help
Old Nov 25, 2012 | 07:30 PM
Sik Eg's Avatar
Default Comfused plz help
So I did my research HT I looked up the 96-97 Type R specs and the 98-00 Type R and I found different specs on both.
I went to JDM ENGINE DEPOT.com
Link to 96-97 Type R : http://www.jdmenginedepot.com/jdm_en...al_Engine_Swap
Link to the 98-00 Type R : http://www.jdmenginedepot.com/jdm_en...al_Engine_Swap
And compared the two diff engine swaps . The specs for the 96-97 says it is
Code:B18C Integra Type-R OBD2 Manual Engine SwapYear:96-97Valve Train:4-CYLINDER, DOHC VTEC, 16-VALVEDisplacement:1797 ccHorse Power:200 HP @ 8100 RPMTorque:134 LBS-FT @ 6200 RPMCompression:11.0:1Red Line:8400Transmission:Weight:700 lbs
Then the 98-00 specs are
Code:B18C Integra Type-R Manual Engine SwapYear:98-01Valve Train:4-Cylinder, DOHC VTEC, 16-VALVEDisplacement:1797 ccHorse Power:197 HP @ 8000 RPMTorque:127 LBS-FT @ 6200 RPMCompression:11.1:1Red Line:8600Transmission:5-SPEED LSDWeight:800 lbs
So my question is woukd the 96-97 swap be best for me seems that is has slightly more
power and torque. Thanks HT
Old Nov 25, 2012 | 07:37 PM
doood's Avatar
been there done that
Default Re: Comfused plz help
everywhere else lists the 98-00 as having more power. it has better cams and a better trans.
Old Nov 25, 2012 | 08:16 PM
Sik Eg's Avatar
From the site you can see it gives you the specs of both so im comfused as to whats the best motor
Old Nov 25, 2012 | 08:17 PM
jbpnoman's Avatar
Someone correct me if I'm wrong here, but the 96-97 motor should be OBD2A, whereas the 98-00 motor should be OBD2B. I'd guy the motor to match the chassis, for simplicity's sake.
Old Nov 25, 2012 | 08:20 PM
Sik Eg's Avatar
Thats still not answering the question of the OP whats the better swap ?
Old Nov 26, 2012 | 05:56 AM
HondaPartsHero's Avatar
Technical Hero
There's like a 5hp difference (cam profiles perhaps) The difference in the swaps are basically in the transmission gearing. The 96-97 has the 4.4 and the 98+ has the 4.7.
Old Nov 26, 2012 | 06:20 AM
Sik Eg's Avatar
Both swaps have LSD but whats the better swap ?
Old Nov 26, 2012 | 06:31 AM
doood's Avatar
you've been given enough information to make an educated decision on your own. how are we supposed to know what's best for you?
Old Nov 26, 2012 | 06:39 AM
JuggerNaut-CTR's Avatar
Slightly bigger cams and 4.7 FD would be "BETTER" imo
Old Nov 26, 2012 | 06:51 AM
Sik Eg's Avatar
Not better for me just better period .
Old Nov 26, 2012 | 06:52 AM
Sik Eg's Avatar
Thanks guys for the input
Old Nov 26, 2012 | 06:53 AM
Sik Eg's Avatar
Its going in my EG
Sik Eg
Nov 25, 2012 08:14 PM
allanonjj
Sep 9, 2012 09:45 PM
Finger Lickin' good
11
Nov 11, 2006 09:50 AM
b18b1b16a2
Nov 25, 2005 06:30 PM
MidoriEK4
Dec 15, 2002 10:26 AM
