Question on 99 GSR Swap in 96 CX
Old 01-05-2013, 02:17 PM
The_CX_GUY's Avatar
Default Question on 99 GSR Swap in 96 CX
This is my first swap and first Honda
Its a 1996 civic CX
Motor 1999 GSR
Engine Harness is 96-98EX 5spd
ECU 96-98 EX so I can pass emissions, from what I was told I needed this.
I am confused on what wires need to be added and what needs to be switched in the Pin-outs.
Can anyone shed some light on this topic for me..
Thanks
Old 01-05-2013, 02:23 PM
Master Detailer
98civdx's Avatar
Default Re: Question on 99 GSR Swap in 96 CX
You wont pass with a 96-98 ECU.
Old 01-05-2013, 02:25 PM
The_CX_GUY's Avatar
Would you know the correct set up that I would need?
Old 01-05-2013, 02:29 PM
Master Detailer
98civdx's Avatar
GSR engine, GSR ecu.
Or hunt down a p28( there is a few others you can use) and have it chipped and tuned. Not sure if this will cause you to fail emissions though.
Old 01-05-2013, 03:09 PM
The_CX_GUY's Avatar
alright thanks.
Old 01-05-2013, 03:15 PM
jbpnoman's Avatar
Chipped P28 won't work, because they won't be able to plug in and read the diag port. You need the OBD2 GSR ECU.
Old 01-05-2013, 03:21 PM
dck1ng69's Avatar
^be careful on the gsr ecu's, I believe the 2000 and 2001 ecu's have immobilizers
Old 01-05-2013, 03:35 PM
jbpnoman's Avatar
Immobilizers are fairly simple to remove.
Old 01-05-2013, 03:38 PM
Technical Hero
HondaPartsHero's Avatar
Why couldn't he just use the 96-98 ecu for the GSR? Sounds like the same emissions testing here in NC which only requires connection to the ecu and all readiness monitors ready no matter what engine year of the engine.
Old 01-05-2013, 03:56 PM
The_CX_GUY's Avatar
That was the issue i was having, I bought the engine with the 99 GSR ECU but it wouldn't plug into the 99-00 si engine harness I had and it also wouldn't give spark at all. So I bought a 0bd2a- obd2b conversion harness, and a 99-00 si ECU which worked and the car fired right up but the fuel pump wouldn't turn off after priming and when i would plug the scanner in it wouldn't read at all. So Now I bought the 96-98 EX engine harness 5spd and the matching ECU, but my issue is I have not a clue on what wires i need to run and which pins need to be changed, and Im pretty sure my car is stuck in limp mode right now cause it wont rev pass 3k
Old 01-05-2013, 05:27 PM
The_CX_GUY's Avatar
Yes, Connecticut is the same way, I cant have a CEL and I need a Cat on the car.. and all codes must be cleared
Old 01-05-2013, 06:02 PM
canadaek's Avatar
read this https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Old 01-09-2013, 07:51 PM
cruizinmax's Avatar
You need an obd2a gsr ecu. I have one for sale.
trucksandtoys26
11-22-2009 09:16 AM
Syndacate
28
02-23-2006 11:23 AM
blackie
07-10-2005 02:24 PM
hotvtec
06-18-2004 12:35 PM
Stifler
11-19-2002 06:00 PM
Quick Reply: Question on 99 GSR Swap in 96 CX
