ls vtec fuel problem help!!
Old Dec 7, 2012 | 05:30 PM
lsvSwagg's Avatar
Default ls vtec fuel problem help!!
ok i have an 2000 civic dx i just did a lsvtec swap intoit its b16 head b18b1 block ls injectors ODB1 WITH ODB2clips . the wire harness is from a si (obd2) the ecu is p28 . the problem im having is the fuel pump works the fuel rail is reciving the fuel but the injectors are not spraying the fuel . i have ran of ideas of what it could be plz help!
Old Dec 7, 2012 | 06:19 PM
lsvSwagg's Avatar
Default Re: ls vtec fuel problem help!!
anyone ?
Old Dec 10, 2012 | 10:14 AM
hybridmiklo's Avatar
is there voltage at the injector plugs when key is on position? Start from there
FYI the ecu grounds the injectors.
mitchell88
Mar 16, 2013 12:56 PM
B Series JuNky
26
Jul 30, 2007 11:01 AM
Sean DM
Jun 12, 2007 01:43 PM
