F20b engine swap questions
Hi, I am a new member here on this site and i had a few questions about an engine swap that i was thinking about doing. I found a f20b swap on hmotors and its around the budget for an engine. Ill be putting this into a 1998 honda civic ex coupe.
My questions are:
What all will i need aside from the things that the motor/tranny come with?
Is there any problems that could come up?
Will this even work without having to do any major frame work?
Id really appreciate any help or directions towards a thread with someone that has already completed a f20b swap.
My questions are:
Re: F20b engine swap questions
For the engine mounts, would there be any specific brand i would have to look into or type of mount? And for the harness and ecu i put a link below to the engine and what it comes with, so if you could, could you tell me what harness and ecu i would possibly need to look at? And the tranny i would be using the 5speed one that it can come with.
http://www.hmotorsonline.com/shop/sc...age&item=30013
I would go with Hasport Engine mounts. As far as the trans I am not sure, only because I am doing the same swap, but I am going to be using my B16 trans (H2B) Just make sure you get the ECU for that engine, and that it comes with the engine harness. This is all the information I have, only because I am still trying to also figure out what I need too. I plan on ordering the F20B from HMO also.
Alright, thanks. I was just going with the trans that it comes for the time being until i find something better. I will be sure to talk to them on the phone or whatever else i can so that i know what they will be sending me for sure. Just if you can please stay in touch or something so that anything you figure out, you can share it with me. Thanks for your help!
No problem, just message me if you have any specific questions. I'll see what I can dig up. I check my PMs muc more often than browsing through threads.
I have it of question to I out an f20b in a 96 honda ek with a chipped p28 and my single cam harness and it hasn't hit VTec or had the check engine like go away!!
SystemAddict
20
05-01-2002 01:46 PM
