Bar'd h22 in INtegra/civic - owners
i wanna bar my jdm h22a in my 95 integra rs db7
its a jdm h22a. type S cams, supertech valve train. CP high Comp Pistons and rings.6 puck clutch, heavy duty pressure plate. lighten flywheel. 3 inch Intake. 62mm Type S throttle body. chipped p28
i have a auto p13 ecu im converting to 5spd - soldering mod -not used
h22 harness- not using but have.
resistor box for fuel injectors- not hooked up but have
charcoal canister-not hooked up but have
vacuum lines- not hooked up but have
egr valve - not hooked up but i have it.
air boost valve
prelude injectors - not using but have them
basically everything to make it California Smog legal.
just a couple questions though
1- does the air boost valve need to be there and hooked up properly ? or a jdm block off plate will do ?
2- will i need to use my resistor box ? right now im running a B series harness modified with NO resistor box.. non prelude injectors
3-im using a h22 type S throttle body obd2 with map sensor on the throttle body. do i have to mount the map sensor and purge solenoid back on the firewall and runn vacuum lines again ?
4- do i need to hook up the intake control diagram and solenoid valve ?
5- do i need to hook up the constant/EGR vacuum control valve?
6- is there anything else i need to do ? to know ?. i have a cat welded on my h22 custom exhaust piping. DC headers carb legal.. I know i need the OEM intake tubing and air box as well.. or will a Carb Legal CAI or SRI work?
7- will the auto p13 converted to 5spd p13 work ? the serial number will be for automatic.. will that matter ?.. * just wondering *
Thanks guys.
air boost valve
Thanks guys.
I'm really 2slow
Re: Bar'd h22 in INtegra/civic - owners
air boost valve
Thanks guys.
air boost valve
Thanks guys.
question 1. Yes, that valve needs to be hooked up properly.
question 2. what injectors are you running?
question 3. I believe you will have to run the map sensor on the firewall. I used the original usdm h22 TB with firewall mount MAP sensor.
question 4. If you get an AEM intake for the 92-96 prelude you don't need the intake control diaphragm and resonator. It's junk anyway.
question 6. A 92-96 prelude intake will work fine.
question 7. The ecu must have the correct serial number for the motor. And the CA ecu has a different serial compared to other states.
PM me if you have more questions. I Bar'd my hatch a few months ago.
I'm really 2slow
quick question :
my jdm h22a has the egr mounted on the intake manifold..its not plugged in * sensor wise or vacuum wise *
will it effect my motor at all ?
does a stock p13 ecu.. throw a CEL for EGR ?
Just wondering...
Just wondering...
If you loved me, you'd all sell me your magic cards to me today
