91 crx hf with 95 integra donor car
I have both cars. Crx is current daily driver. I'm doing the rear disc swap along with swapping in the b18b engine into the crx. My main question is does the integra have all the parts I need to do the engine swap or do I need earlier integra parts also? I know I will need to get motor mounts and a wire harness jumper. Will the hubs, axles, etc work off the integra? I'm new to Hondas and for the last year I've been reading as much as possible online but as you know there's always mixed opinions. Thanks for all responses. Rudeness will be ignored so save yourself the trouble.
Re: 91 crx hf with 95 integra donor car
Should have most of the stuff you need. Your gonna need mounts, shift linkage and
a jumper harness. Maybe have to run a couple wires.
thats not all u need ur gonna need a rear t bracket from an 91 integra if u dont have a b16 in there already which is why i believe ur doing the swap ur gonna also need the steering knuckle(spindle) from a crx si....it is possble to use the integra spindle u have now but ur gonna need a major camber kit for upper control arms. also ur crx is cable trans and the integra is hydro so u will have to either buy a cable to hydro conversion (hasport sells em) ur also gonna have to cut off the front motor mount....also the shift linkage will have to be cut 2 3/8 inches and welded back together i believe u can look dat up quick
Thank you. Cutting and welding is no problem for me. I'll look around for the trans bracket. Why do I need to cut off the front mount? Does that mean ill have one less mount then?
Yes with hasport and others you'll only have 3 mounts, don't worry they're very strong,
but they'll shake the car some lol. When you by mounts just make sure you get ones for
a hydro tranny.
a hydro tranny.
