1992 civic, zc mini me, intake manifold wiring help
alright so my hatch came with a sohc zc non vtec motor, i have put a d16z6 head on in. here is the problem. with the p28 ecu hooked up i get so many codes, all relating to intake manifold sensors, and the car bogs when i try to drive it. with the old non vtec ecu, still get a code didnt read it but the car runs "better"
so im wondering what i have to do to fix the sensor problem with the p28, all the sensors have the same clip, are they plugged in differently on the z6 manifold because of placement?
if i didnt include something that could be of use please let me know
Re: 1992 civic, zc mini me, intake manifold wiring help
yes vtec is wired up, and i got all the codes to go away, except for the EGR, which my car has never had, the p28 thinks it does so its throwing the code. which sucks i hate seeing the check engine light. i was kinda able to drive the car, it ran out of gas and the altenator belt broke so i dont know if its driving right still
im running a mini me swap and im not having any problems since it was converted to multi port and im useing a virgin p28
Technical Hero
Post the code and stop all the guessing. A p28 doesn't use a knock sensor so that shouldn't matter at all. Why are you not running an 02 sensor? You need the primary 02 unless your ecu has a program to delete it.
sorry for the late reply, i got all the codes to go away, but it still bogged at low rpms, and only when warmed up all the way, but all the codes are back
ed6teto: you're thread jacking and confusing two people who are trying to help the original poster. Leave as you have nothing to contribute.
If you have something to help the op then give it up.
No one cares about your subframe here.
gabriel0830
03-18-2013 08:46 AM
d16singlecammer
06-21-2005 05:07 PM
